saginaw power steering box
how hard is it to fit a saginaw steering box to a 1969 302 3 on the tree truck i cant find the bendix setup so i guess this will have to do, how to cut the shaft down ?
re: saginaw power steering box
Not hard at all....they were used from '68 up through '79 on all F100-F350 trucks, so they're in every junkyard in the country.
As for the column, it's still highly adviseable and much less of a hassle to get a PS column instead of shortening your MS column, but if you want to give it a try, read this:
http://www.fordification.com/steering-column.htm
if u find a another bendix let me know
thanks
thanks
