Huh? The fittings are two different sizes. Plus the pressure line has a fitting on each end. How did you manage to do that?jp2005 wrote:You guys want good laugh I figured out the problem. I accidently switch my lines, I had the pressure connected to the return and vice versa off the gear box.Do you know if this will cause any damage?
Ford vs Saginaw steering pump
- HIO Silver
Re: Ford vs Saginaw steering pump
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
I had custom hoses made to fit. I had to get them remade again.
Thanks JP! Ms. Cordova is a factory 1969 Ford F100 Ranger with a 390, Front disc brakes, Cordova copper orange, behind the seat box
- abyars111
jp2005, how does it drive with the Saginaw compared to the old Ford/Thompson pump?
Anthony
1970 F250 Crew Cab 2wd 390/2v short bed
2004 Eddie Bauer Expedition
1955 Chevy 210 4dr Sedan
- timmytim
love my Saginaw/ this pump doesn't make noise at all.
buy'em dirty sale'em clean
get more money for the same
machine.....
My 1967 bump: http://www.fordification.com/forum/view ... 09#p668209
My 1970 Bump: http://www.fordification.com/forum/view ... 16&t=50726
- Mancar1
I swapped to the Saginaw on the 68 CS, the feel is better.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Its really smooth with Saginaw pump, Im thinking about switching my new truck to this pump. I read a story where a guy drive close to 3,000 miles with no fluid in pump, so there pretty bullet proof. I guess the engineering was better when they were made over ford pump.abyars111 wrote:jp2005, how does it drive with the Saginaw compared to the old Ford/Thompson pump?
timmytim wrote:love my Saginaw/ this pump doesn't make noise at all.
agreed!!!!
- abyars111
Thanks for the feedback. I'm going to start shopping for brackets to mount one on my FE and do the swap sometime. If anyone has any suggestions for a FE bracket please let me know.
Anthony
Easy! CVF racing! Best prices online!abyars111 wrote:Thanks for the feedback. I'm going to start shopping for brackets to mount one on my FE and do the swap sometime. If anyone has any suggestions for a FE bracket please let me know.
Found this article, not sure if it can be of any help. http://classicbroncos.com/saginaw.shtml
My build thread...http://www.fordification.com/forum/view ... 22&t=67317
- abyars111
That's a good article. I wondered if there would be fitting differences. The pump in this article had a female vs. male issue.
Anthony
I'm going to add a Saginaw to my list of things to do.
Bill
68 F100 Ranger
73 F100 Ranger XLT
Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in garages. (Apologies to Kenneth Grahame.)
68 F100 Ranger
73 F100 Ranger XLT
