^&*(() electronic ignition
fomocoguy
Re: ^&*(() electronic ignition
Post by fomocoguy »
Those control modules are notorious for crapping out all of a sudden. I used to carry a spare one around in my 78 thunderbird just in case.
Joe
1971 F100 flareside 8ft
2006 Dodge Ram 2500 cummins
2005 Ford Ranger
19674x4
Post by 19674x4 »
well it is the ignition switch, i can jocky it back and forth while pushing the starter button and it wil try and catch. does anyone know if one from a 74 Galaxie 500 Wagon will work? they both had 351's at one point. lol ill pull the module from it and hopefully there are both the same color and see if that helps.
My Photo Album
i think i said i think not i believe or know for a fact that it was set in stone before caveman invented god. but the color codes of the boxes are the aftermarket colors. and the colors have to do with what performance and so forth you want out of your stuff. but i think that the regular stock module boxes will alll intherchange and work with any engine that has a need for a module. except for maybe 6 cyl to a v8. that could be a difference. i would just try it and see.
Dragon
Post by Dragon »
19674x4 wrote:well it is the ignition switch, i can jocky it back and forth while pushing the starter button and it wil try and catch. does anyone know if one from a 74 Galaxie 500 Wagon will work? they both had 351's at one point. lol ill pull the module from it and hopefully there are both the same color and see if that helps.
The ignition switch has a different connector.
Old Fords Rule
Was a Ford Service Tech
98 Volvo S70 2.4T Auto
My Gallery
Spark test
19674x4
Post by 19674x4 »
well it was the control module. took a spare i had in the wagon and the truck fired right up. now i just gotta figure out why the secondaries on the carb aint opening up.
My Photo Album
Dragon
Post by Dragon »
What kind of carb?
Old Fords Rule
My Gallery
Spark test
19674x4
Post by 19674x4 »
edelbrock 4bbl. mechanical secondaries
My Photo Album
Dragon
Post by Dragon »
The secondary linkage is bound up usually at the throttle shafts.
Old Fords Rule
My Gallery
Spark test
willowbilly3
Post by willowbilly3 »
Do those carbs have the secondary lockout on the choke? I know most 4 bbls won't open the secondaries until the choke is fully open so if it's a little lazy, no secondaries.
Dragon
Post by Dragon »
Some do like my Holley does. But it will be obvious. The choke looks like it is a part of the secondary linkage when the choke is on.
Old Fords Rule
My Gallery
Spark test
19674x4
Post by 19674x4 »
it aint the choke, i can have the choke manually open all the way and they dont move. i bet they are bound up inside
My Photo Album
Dragon
Post by Dragon »
Yep sorry to say.
Old Fords Rule
My Gallery
Spark test
