^&*(() electronic ignition
19674x4
Post by 19674x4 »
Soo my 83 with the 460 has no spark. I presume the module in the dizzy is good. I tried another coil and still no go. The only thing i can think of is either a bad ground strap or the control module on the fender. I even tried running a wire from the battery to the coil and jumping it and still no go.
Any idears?
My Photo Album
Re: ^&*(() electronic ignition
duraspark? control module? just a guess. those modules can be checked at the parts stores i think. i love my points.
Dragon
Post by Dragon »
The dizzy if you have a multimeter will get a voltage on one wire from the module on the fender and get another signal sent back as the dizzy turns. You need to check the connectors and the wires for those signals. Or you can buy parts that are not needed. There are plenty of Duraspark diagrams if you do a web search.
Old Fords Rule
Was a Ford Service Tech
98 Volvo S70 2.4T Auto
My Gallery
Spark test
willowbilly3
Post by willowbilly3 »
You can check the pickup coil in the dist. One wire should be a ground and between the other 2 you should get about 1 volt dc when cranking. I think primary resitance on the coil is 1-3 ohms and secondary is 6000 give or take a thousand. If you have power to the coil and those things check out then it is probably the module, or just try a known good module, everyone should have a spare anyway. I get the OEM ones from junkers, better than the aftermarket ones.
To check the coil, disconnect all wires. Primary is across the 2 small connectors and secondary is across each small one to the center term. You need a volt/ohm meter. They are inexpensive. I prefer digital for general use.
MadMaxetc
Post by MadMaxetc »
willowbilly3 wrote:You can check the pickup coil in the dist. One wire should be a ground and between the other 2 you should get about 1 volt dc when cranking. I think primary resitance on the coil is 1-3 ohms and secondary is 6000 give or take a thousand. If you have power to the coil and those things check out then it is probably the module, or just try a known good module, everyone should have a spare anyway. I get the OEM ones from junkers, better than the aftermarket ones.
:yt: ...just like points, never hurts to have a spare. There are a dime a dozen at the salvage yard. 90% are still good.
Dan
FORD Girl
Photobucket Pictures
19674x4
Post by 19674x4 »
thanks. i havent messed with it yet. I have a guy wanting to buy it and he sounds intersted running or not. if i dont hear back from him ill mess with it. Anybody want a 82 f250 4x4 with a c6 and a 460 for 500 bucks?????? lol
My Photo Album
willowbilly3
Sorry, not enough pedals for me.
Remember the laws of the universe, any part you carry a spare for will never go bad. This does not apply to highboy u joints.
fitzwell
Post by fitzwell »
willowbilly3 wrote: Remember the laws of the universe, any part you carry a spare for will never go bad. .
Greatness :lol:
i gotta remember that one
19674x4
Post by 19674x4 »
well turns out its the ignition switch is touchy. Now it acts like its not getting fuel cuz it will run for a while(10 seconds) then cut out and die. i didnt mess with the carb at all before its issues
My Photo Album
can you hold upwards on the switch while its running to keep it running? or maybe the fuel is running back into the tank.
Dragon
Post by Dragon »
19674x4 wrote:well turns out its the ignition switch is touchy. Now it acts like its not getting fuel cuz it will run for a while(10 seconds) then cut out and die. i didnt mess with the carb at all before its issues
I had a switch do that it was an original 1969 F350 switch in 2004.
Old Fords Rule
My Gallery
Spark test
19674x4
Post by 19674x4 »
i can rev it up and half way through throttle it will die out
My Photo Album
Dragon
Post by Dragon »
19674x4 wrote:i can rev it up and half way through throttle it will die out
Not switch. Dies flat or sputters/slows down getting weak until it dies?
Old Fords Rule
My Gallery
Spark test
runs until module is warm and then shuts down. i am still betting module.
Dragon
Post by Dragon »
Me too!!
Old Fords Rule
My Gallery
Spark test
