mounting engine mounts. how do you do it?
OldRedFord
Post by OldRedFord »
rjewkes wrote:wouldn't the 460/428 towers from a late 70's 2wd also work? push comes to shove?
Yes they will. Thats what Im using in my truck.
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
zakt
re: mounting engine mounts. how do you do it?
Post by zakt »
now what mounts are the best in 2wd....Ive been thinking about getting the towers from L&L now why would I get the trans dapt vrs the L&L and so forth, which is the strongest etc..etc.. thoughts? Putting the 460 in my 2wd 72 f350....
Todd
BobbyFord
Re: re: mounting engine mounts. how do you do it?
Post by BobbyFord »
zakt wrote:now what mounts are the best in 2wd....Ive been thinking about getting the towers from L&L now why would I get the trans dapt vrs the L&L and so forth, which is the strongest etc..etc.. thoughts? Putting the 460 in my 2wd 72 f350....
Todd
Get stock mounts and perches out of 73-79 F- Series with 460. They bolt right in.
averagef250
Post by averagef250 »
L&L is junk, I've never heard of trans-dapt, but they look considerably cheezier than the L&L stuff. The factory Ford mounts are the toughest and best of all of them.
1971ford
Post by 1971ford »
i suggest getting ones out of a dent. i really really wish i did instead of wasting $130 on these cheezy mounts i got. they should be pretty industructable with the gussets we added though.
-Ryan
zakt
Post by zakt »
anyone have a set of 73-79 F350 460 2wd mounts laying around??
:D
Just found these, are they decent?? (no gussets on these either)
http://www.autofab.com/2wd460.htm
zakt
Post by zakt »
Just checked ebay will this bolt into my 2wd 1972 F350 for installing the 95' F350 460??
http://cgi.ebay.com/ebaymotors/73-79-fo ... enameZWDVW
1971ford
Post by 1971ford »
ahhh the autofab ones. autofab makes really good off-road quality stuff. those should be pleeenty strong. expensive but strong.
-Ryan
Hawkrod
Post by Hawkrod »
zakt wrote:Just checked ebay will this bolt into my 2wd 1972 F350 for installing the 95' F350 460??
Yes, exactly what you need. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
green70
Post by green70 »
why dont you just weld them,you could tack em while the engine is still in,then you know there lined up right :2cents:
rjewkes
Post by rjewkes »
how does the the side attached to the 460/428 bolt to the towers in the truck? i don't see a hole in the tower.
fuelly.com
Hawkrod
Post by Hawkrod »
The holes are top to bottom, the angle of the picture makes it hard to see. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
1971ford
Post by 1971ford »
green70 wrote:why dont you just weld them,you could tack em while the engine is still in,then you know there lined up right :2cents:
if i had a welder i would probably do that. i dont really want to have my boss bring the welder truck up to do it
soo many reasons for me to get a welder :D
-Ryan
rjewkes
Post by rjewkes »
Thanks Hawkrod, Do you mean like a leaf spring mounting shackle? is it a clovis deal on them?
fuelly.com
Hawkrod
Post by Hawkrod »
Look at this, you will see there are two bolts to hold the insulator. one goes through the block mount and the other through the frame mount. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
