-Does Anybody Know?-
Does anybody know how to do this? http://www.fordification.com/galleries/ ... p?pos=-735
an can guide me through on how to do it!***
Not sure how to do it... it requires either a kit or some fabricating on your end. This company has fiberglass tilt front ends and a kit that includes the hinges.
http://usbody.com/
Patrick
http://usbody.com/
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
- Mohillbilly
re: -Does Anybody Know?-
Wow. That looks like it would take 3 men and a boy just to lift it up. A cantilevered fiberglass unit weighs enough, but mabe those old hood hinges would lift it ok.
70 Custom LWB, 302-2V, 3 on tree
i see what ur talking about cut out a handhole in the hood and pull back on it like they do on the big rigs
i thought about taking it all off cut the end part of that frame weld the hinges on it then put some cinderblocks under it and put itall back together i'll try it it prob wont work but im gonna give it a shot
- customcrewcab
that one is not the best setup. you need to weld the front together and add some bracing. this one is powered and pretty simple. check out the pics
- customcrewcab
sorry second pic is the same this is the one i wanted to post.
heres the truck i wanna do that to its a 71 ford 2 or 350 not for sure when i bought it
but its a new project im gonna make it a tool truck...
- customcrewcab
the 65 bumper stays in the same spot too. the other one has the frame cut in the front. this setup works pretty good and looks pretty clean.
- customcrewcab
if i build another crew. i going to build a 4x4 with diesel and a tilt front. if ever finish my 70
then theres my 64 hard top falcon thats sitting.
