Hello
I am curious is any one has any info on the picture I have attatched. I am assuming that it for trailer brakes but am confused why it says max min. The other question is if it is for trailer brakes can I disconnect it without to many problems occurring. I realize I would have to either plug the brake line off the master cylinder or get a new outlet for the from brake lines. Any help would be greatly appreciated.
Thank You in advance.
Jamz[/img]
Anyone have any info on this
Looks like a trailer brake to me.
If it ties into the brake line, most of them just came with a "T" which you can remove then simply screw the existing brake line back into the master cylinder. (Then Bleed obviously)
Min>Max just adjust the sensitivity so that you can taylor the trailer brakes to the load.
re: Anyone have any info on this
Hey thanx for the quick reply and info.
- bluef250
It is for trailer brakes.
As you apply your truck brakes, the unit causes the trailer's electric brakes to apply. The trailer should brake just a little more than the tow vehicle hence the max/min. If the trailer does not brake it can whip around when the tow vehicle brakes which is not a good thing. Have run many miles without trailer brake and not had a problem, but there is always the first time. You have to drive at least 1/2 mile ahead of where you are anticipating the worst and reacting accordingly.
- wildcard
- binder56jd
now serving #235
now serving #235
