mustang II
edgar
mustang II
Post by edgar »
where can i get the mustang II suspension? or a website?
re: mustang II
Here are some links for you to check out:
www.fatmanfab.com
www.jimmeyerracing.com
www.killerridez.com
www.grantkustoms.com
www.hillshotrods.com
www.ifcustom.com
The first link to Fatman Fabrications is where most get their Mustang II kits. Keep in mind that these really aren't straight bolt-on kits...there's a little cutting/welding/fabrication necessary. If you're handy with a set of tools and a welder though, you shouldn't have any problems.
The other links are to site with similar products, and one of them might have something you'd be interested in.
layedout72
Post by layedout72 »
fatman IS about to come out with a complete bolt on, from the word on the streets :)
marz68
Post by marz68 »
I heard the same, Fat man will be selling a bolt on MII suspension. I remember seeing a picture of it to.
marz68
Post by marz68 »
I think that the only part that you have to weld on that bolt on kit is the boxing plates.
I guess that don't make it 100% bolt on. :hmm:
alvinator
re: mustang II
Post by alvinator »
wonder if you could find a good set of MII suspension in the salvage yard
layedout72
i guess you could always use the stock MII crossmember, but its not going to be pretty, nor match up with your frame i bet. (different width and style mounting maybe?) just wait for the bolt on kit to be released, that may be what I have to do marz, sounds a LOT easier, and the stock floor could be done then.
