New guy here...still trying to decide if I have enough time to tackle this '69 F100.
A good friend has a 67 Chevy pickup that came with 4 wheel drums. He easily went out and bought a complete kit that included EVERYTHING (spindles and the whole deal...minus fluid) to swap to discs. Does anyone produce such a thing for the Fords?
Thanks!
-GT
Aftermarket Disc Brakes for 69 F-100?
- flyboy2610
re: Aftermarket Disc Brakes for 69 F-100?
Yes. Ford did. You can find these kits on the front end of '73-'78 pickups.
For more info, click here:
http://www.fordification.com/discbrakes01.htm
Good luck!
Good luck!
- xxxtina63
I think Stainless Steel Brakes has a drum to disk conversion that allows you to use the 67-72 spindles, but they are REALLY expensive. Would be better off converting to a mid 70's OEM setup.
My FORDification Photo Album
- 460 crew
Here is another option for the rear swap. http://www.blackbirdscustomtrucks.com/index8.html
- thorn1968
Yep, Master Power has what you need.thorn1968 wrote:mpbrakes also makes kits for all four corners power and non-power brake options
http://www.mpbrakes.com/index.cfm
Thanks for all of the replies!DuckRyder wrote:Yep, Master Power has what you need.thorn1968 wrote:mpbrakes also makes kits for all four corners power and non-power brake options
I checked out Master Power....over $1K for front power disc brakes? Ouch. Am I missing something?
-GT
