71 "B" paint code
71 "B" paint code
I am sure it is a "B" - not an 8, or a 3, or any other letter/number. Truck seems to have the original color, or close to it. I don't think it was swiss aqua (which I think is "3"). See the tag attached.
Any guesses?
Any guesses?
- heep70
Wind blue (light blue) for 72. Looks like yor rig is blow around the vin tag.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- Galaxie64
Interesting, looks like a B to me. On a side note mine was originally blue but I forget the code on it. Gonna go look now.
NVM mine is "WM"
NVM mine is "WM"
'68 F150 2wd
'48 F1 (Flat 6)
'51 F3 (Flat V8 )
'56 F350 (engineless)
'48 F1 (Flat 6)
'51 F3 (Flat V8 )
re: 71 "B" paint code
It is a B code, sorry if that wasn't clear.
IT's a friends truck so it s not handy to check, but has a explorer blue interior (which matches the door tag). I think it has been resprayed, but in close to the same color? Just guessing on that. sort of doubt it was maroon with that interior.
Paint codes can jump a lot from year to year, this truck looks to be in the middle of the production run, so less chance of it being a 72 code?
thanks.
thanks.
You said the truck has an "Explorer blue interior"....is the truck an actually Explorer? That might be why the code isn't listed, since the Explorer was a special mid-year model and the codes wouldn't have been listed with the others.
I've got a final 1975 copy of the Ford Master Parts Catalog for the '67-'72 trucks on microfiche that should have that code, give me a couple days and I'll see if I can find it.
It is a custom, but has padded door panels. also has the upper trim molding. Unusual maybe? Guess it could have been "upgraded" at some point in time by a previous owner.
I don't think it is a true Explorer, no badging to indicate that. I called it explorer blue based on your 71 vin decoding info. It lists this as the interior color available for the Custom trim level, and this matches the door tag info.
Am I off a spot? I have the top line as 131 B F103 1 4 C 17
Longbed, Exterior color B, 4500 GVR, right?
Then I read 1 as Custom Trim level color explorer blue
Then I thought 4 would be the bed & body type - flareside, styleside, etc.
c 17 would be lt duty 3 speed manual, 3.25 rear end gear.
Maybe I am reading the 71 chart wrong. It's a little confusing to me.
- rjewkes
also sometimes it is a different door/different vin tag.
fuelly.com
fuelly.com
