Wanted: Rear Flexomatic Spring Compensator
I am in search of a rear flexomatic spring compensator for the driver side. Mine is fairly rusty.
- basketcase0302
Re: Wanted: Rear Flexomatic Spring Compensator
Are you talking about the BUMP STOP part number 4730 in this tech image?="T_Bird Guy" I am in search of a rear flexomatic spring compensator for the driver side. Mine is fairly rusty.
If so-Bronco Graveyard has them, (prob sure DC and a few other vendors also have them).
https://shop.broncograveyard.com/1973-1 ... nfo/23100/
Part number 5A709 is the part I am looking for.
- basketcase0302
Pretty sure you're looking for a "white elephant", (probably a boneyard or a member here with an old frame being the only option) as I don't ever remember seeing these ever being repopped. Find out member here Tom, (North Carolina area) as he also had a lot of resources for hard to find obsolete parts like this.
Don't rule out the early Bronco guys as a resource for this part though as I remember the ones on my 76' EB also having bad rust issues, (I wound up drilling 1/4" holes into the bottom of mine to keep the mud/dirt washed out).
Have you tried reaching out to Green Sales, (prob my last option of a vendor):
http://greensalescompany.com/
Is it the part that bolts to the frame mount that's suppose to when flexed push down on the spring? If so I have a pair on some old springs behind my shop.
60 Mercury Comet
65 Ford Econoline
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
