Rod bearing clearnace on a 351W
Zorm
Post by Zorm »
Does anyone have the proper clearance I need to look for when using plastic gauge. This is a 1993 non roller engine, all stock. I checked the measurement of the crank rod area and its still in spec. 2.310. So I got standard bearings, now I want to put the new bearings on and use plastic gauge to check em. Do I use the red or blueish piece. Oh, this will only be a weekend driver, nothing high performance.
Also, the bearings I got have the oil hole, the old ones don't, will that matter?
thanks for any help.
Von
Re: Rod bearing clearnace on a 351W
Post by Von »
tnlprt
Post by tnlprt »
.001 per inch of journal size
