Good thought could be. The 361 and 360 are different. Different heads with odd valves weird pulleys, and some other external differences. Normally those are pretty obvious.MadJoe wrote:After looking at the Edelbrock website, this intake specifically states "will not fit heavy-duty 361 c.i.d. and 391 c.i.d. Ford truck V8's". When I had my intake manifold cleaned, the guy corrected me as I showed him the 360 in my truck, saying "361 actually". Is there a way to tell the difference (is there even any difference?)? I thought the 360/361 were just different ways of describing the same engine because people started differentiating truck 390's as 391's. Can anyone clear this up? And could this have anything to do with the LGreen72F's problem?
-Joe
With this issue I thought back to Barry from survival's book. He mentioned how machined heads and other items can cause bad intake fitment. I am wondering if machined heads machined block deck in this engines past. That could dang sure be causing some issues. still a lot at .5mm
