302 serpertine pullys and brackets on a 351 W ?
GonzoTx
Post by GonzoTx »
Can anyone tell me if the serpentine belts and brackets from a 302 can be made to fit a 351 W ? I'm doing the Crown Vic IFS and Explorer rear end swap and I think the serpentine would look better and work better for the power steering.
Thanx !
Re: 302 serpertine pullys and brackets on a 351 W ?
I'm not sure everything will match up to the block correctly. The deck height on a 351W is taller than a 302 and the heads sit at a different angle. You would do better going to a salvage yard and pulling the front parts from an 80-early 90's 5.8L F150, Explorer or Bronco. Be sure and get the crank pulley, timing cover and tensioner..
GonzoTx
Post by GonzoTx »
Thanx Randy !
