what now
- 19674x4
what now
ok i am doing the rear brakes, and i got the axle out, the tightening nut, adjusting nut and the outer bearing out, what now, the drum won't budge. i adjusted the brakes down. i push the adjuster wheel up, right?
My Photo Album
- heep70
re: what now
Didn't you have problems on the front drums also
Man, i can't remember which way to turn the adjuster. I do believe you have it right.
Does the drum drag more or less when you adjust it?
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
if you have it adjusted out as you say then the drum shouldn't drag when you turn it. if it drags turn it one way or the other until it stops dragging and then take it off. if it doesn't drag. and is still stuck you may have to take two screwdrivers one oppisite the other behind the drum and pry out ward so the drum will come off. it may have a groove in it that is catching inside the drum.
- 19674x4
re: what now
i got it, and yes i did have trouble with the front
also my real wheel seals are bad so now i have to get new ones and while i am at it i'll get new berings.
off to install my new alternator
My Photo Album
- flyboy2610
re: what now
Look at your drum closely around the wheel studs and see if there is a clip on one stud. The factory put a clip on there to hold the drum on until the wheels got installed. Or there may be a screw holding the drum on, for the same reason.
