69 F100 S/S
rollercam1
Re: 69 F100 S/S
Post by rollercam1 »
Now to deal with the front frame horns. The drivers side is bent in a little bit. The passenger side is bent out a little bit. It's 3/4" out of square with the frame. I believe the frame horns are supposed to bend out slightly. Does anybody have a straight front frame horn section that they could measure for me? The driver's side has had the bumper bolt holes elongated towards the outside, and the passenger side does not. The bumper bolts up good though.
rollercam1
Re: 69 F100 S/S
I got the stainless brake lines for the front brakes bent and in place last night. Really like my new brake flaring kit!Image
rollercam1
Re: 69 F100 S/S
Finished up with the boxing plates on the front frame horns. Got the drivers side straightened out. Welded on some tie down lugs for when I have to haul it long distance. I also got the frame paint today. Mixed in 24 grams candy purple pearl in with 1/2 gallon of deep black. Totally looks black until you turn the paint stick and it glows dark purple. Also picked up the stainless hardware for all of the suspension.
rollercam1
Re: 69 F100 S/S
Working on stripping the frame for paint. POR-15'd the core support, radius arm bushing shafts, brake calipers and cab mount flanges. Got some parts in today for the rear-end. Going from 3:50's to 3:70's. So, if anyone needs a brand new set of Richmond Gears.... Plus, the new paint guns! No more siphon guns for this guy!
rollercam1
Re: 69 F100 S/S
Finished up fabbing up the rotisserie, hung the frame and finished up with the welding and cleanup. Now to finish the rearend and poor boy paint booth and then it's painting time!
rollercam1
Re: 69 F100 S/S
Finished up with painting today. Looking forward to assembling the chassis!
rollercam1
Re: 69 F100 S/S
rollercam1
Re: 69 F100 S/S
Monkey-1
Re: 69 F100 S/S
Post by Monkey-1 »
Wow! Looks killer.
-Monkey-1
1985 F-150 Build Thread (CV Swap, 4.6, Frame-Off) https://www.ford-trucks.com/forums/1519 ... 4-6-a.html
1977 F-100 Flareside Build Thread (CV Swap, 4.6, Frame-Off) https://www.ford-trucks.com/forums/1545 ... hread.html
Studmonkeyracing.com
studmonkey@bellsouth.net
rollercam1
Re: 69 F100 S/S
Finished assembling the rear end. Got the motor installed for the final time hopefully. Starting to get the front end underneath it. The polishing is looking nice!
rollercam1
Re: 69 F100 S/S
Well, it's finally a roller!
Image[/img]
[imgImage][/img]
[imgImage][/img]
Image[/img]
Image[/img]
Image[/img]
Image[/img]
Image[/img]
rollercam1
Re: 69 F100 S/S
