I have a 71 F100 camper special with a 390, power steering and air. I know originally this truck ran Type F just like my mustang, but when my dad rebuilt the truck he had the trans re built and a shift kit installed in the mid 90s. I'm not sure if these newer clutches and shift kit still will run Type F or will it now be Mercon? and he cant remember what he was told to put in it. I know I had the trans re built in the mustang back in 2006 and I still run Type F in it. I do not want to ruin the trans. Just not sure.
Thank you any one who can help.
Trans fluid
Re: Trans fluid
Type F won't hurt it.
You don't want to put Dexron / Mercon in a tranny made for type F
You should see how many different fluids that are made for specific tranmissions these days.
- tqwrench
Re: Trans fluid
From what I read, if it was rebuilt in the last decade you're green lighted to use Dextron/Mercon. All the rebuild kits are compatible with it. If it's never been apart, keep using Type F.
Mine appeared to have never been removed so when I did a fluid/filter/pan gasket, I went back with Type F. It performs well.
Dextron/Mercon has friction modifiers that Type F does not have, so clutch material that is not designed for Type F will get damaged if used with Dex/Merc.
1969 F-250 390 Camper Special
Re: Trans fluid
Thanks for the info. I just spoke with my dad and he remembered that the guy who built the trans told him Type F.
Thanks for the responses.
Re: Trans fluid
Try putting B and M trick shift in your GM vehicle....Hint hint It is Type F fluid
My C6 was built 6 years ago and runs Type f trans fluid
- radioactivelarry
Re: Trans fluid
If you are unsure what type fluid to use just go with a synthetic like Amsoil or there are a couple of good synthetics out there. The synthetics are compatible with all auto trans. Your trans will last longer and run cooler.
http://www.amsoil.com/shop/by-product/t ... e=ATLQT-EA
Cost a little more but your trans won't wear and you get 100,000 miles between changes, no baloney! Try it out.
Democracy is two Wolves and a Lamb voting on what to have for lunch. Liberty is a well armed Lamb.
Ben Franklin.
My Motto: I wish I had less to do, more time to do it in and got paid more for not getting it done.
Ben Franklin.
Re: Trans fluid
thanks much. i will do that. synthetic it is.
Re: Trans fluid
Had my 1969 c6 rebuilt about a year ago and they said type f.
It changes gears good and I have not problems.
