Hi guys,
Ok after pulling off the trailer and taking it down the road for some Duke boys fun I have the '69 down to a bare frame .I need to know the best/most economical way to get posi-traction, it has original 9'' , tag still in tact 3.25 gears . What gears you fellas recommend ? It has a 360, gonna do a rebuild, accepting advice in this area also (bought it as a 428 but after tear down and stroke measurement low and behold its a 360 ! ,, no worries didn't have much faith in it being a 428 anyway )Also want to go to power disc brakes ,plan on lowering 4'' with DJM kit to match CV front.
Thanks in advance , Jeff
Advice on goin to posi and disc brakes
Re: Advice on goin to posi and disc brakes
Your truck will have 28-spline axles. This means you would have to locate a 28-spline Traction-Lok differential from a wrecking yard donor or purchase one brand new. They come in two versions: 2-pinion or stronger 4-pinion differentials.
1969 was the first year of the Ford Traction-Lok differential ('57-'68 was the Ford Equalok). If you are lucky enough to find a wrecking yard TL differential, stay away from the '69 model Traction-Lok. It is weaker and more prone to breakage than the '70-'86 version.
...and, there are no 'posi' (short for, 'positraction') differentials in a Ford. That's a General Motors trademark name/reference.
For front discs, any '73-'79 F100 or '75-'79 F150 front suspension/discs will swap over.
I installed '77 F100 front I-beams/radius arms/discs onto my '69 SWB F100.
http://www.ford-trucks.com/forums/13395 ... drums.html
I purchased the PowerTrax No Slip for mine http://www.summitracing.com/parts/pwt-9 ... /overview/ Installation was simple. Haven't actually driven with it yet but it has good reviews.
- Ranchero50
Most economical is to weld the spiders or install a mini spool. I recommend neither.
Personally I'd find a late model rear and drop it in vs. do any aftermarket conversion on the 9" for disc brakes. You'll also most likely end up with a posi rear if you shop smart. I'd also leave the 3.25 gears in place if you don't plan on installing an OD transmission.
It is hard to beat a Detroit Locker.....mechanical, dependable, great history, and used in some of Ford's premier vehicles of the past. My
2017 Ford Raptor
1970 F250 4x4
1975 Ford Bronco
2017 Ford Raptor
1970 F250 4x4
1975 Ford Bronco
Thanks Guys,
I think i will go with an Explorer 8.8 with Traction-Lok , gets me what i'm after at a reasonable price ( junk yard says $200 ), between the PowerTrax and Disc brake kit it's a no brainer money wise. I'm unsure about mods I have to make, but hey that's what I signed up for when I decided to do this build, know of any threads on this swap ?
Thanks Again !!
Thanks Again !!
