Hello, new member here from TN
This is a great forum that has been a wealth of info for mr since rescuing a 72 longbed a few months ago
I'm making a shop truck to pull my trailer & throw parts in the bed so I'm trying to do this on a small budget, not worrying so much about "pretty" as I am reliability.
I own a small engine shop & work on a lot of riding mowers, garden tractors, etc.. & want something I'm not afraid to get dirty or get a scratch on. This truck had been sitting for many years & I bought it from a guy who had bought it 3 months prior & got it running. I'm in the teardown process right now & this forum has been a lifesaver.
I used to restore first gen Mustangs back in the 90's & have kind of gotten out of the rhythm so alot is coming back to me on replacing sheetmetal, etc..
I will post some pics a little later & look forward to your input
THANKS AGAIN!
Bryan
THANKS AGAIN!
Bryan
- Mancar1
Re: Hello, new member here from TN
Welcome aboard from Gerber, Ca.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Im used to postng pics pics from my hard drive, I see you cant do that here so I have to set up image shack or something I guess
- 1970FordTK
Welcome from North Carolina.
- TexasVine
1967 Ford 100/352/4 speed/PB/LWB
2014 Ford F150 KingRanch 4x4
Sure you can! http://www.fordification.com/forum/view ... w=previousBryan_Tenn wrote:Im used to postng pics pics from my hard drive, I see you cant do that here so I have to set up image shack or something I guess
- popeyes71
-Popeye-
1971 F-250 4x4 Highboy
- fireguywtc
Bill
2024 F350 CCSB, darkened bronze
"I ain't as good as I once was But I'm as good once as I ever was"
https://photos.google.com/photo/AF1QipM ... mfKhMOFcFj
1971 F100 SWB 302 2WD (Work In Progress)
2010 F250 4X4 6.4 Power Stroke / lariat Black
2020 F150 4X4 3.5 Eco Boost / icon Silver
all of my pics on my computer are too large so I have to resize them to post. I will try to post some after while
heres a pic of how it looked when I got it
All in all, she looks pretty solid
it is really. I'm gonna put a DS floor pan in, I can do a little patchwork on the PS. Someone has put cab mounts over the existing ones & didnt weld or rivet tS one has some rust so once I cut the floor out, unbolt the mount, I can see whats what.
I have the bed & front clip off now & 302 & C4 out. Rear is a 9" with 3.50 gear. Engine has within 15% compression on each cylinder, so I'm really on the fence about what to do with the engine. I'm trying to do this on a shoestring budget & I can't justify doing $400 of machine work on an engine that runs good, has good compression, etc... when that $400 could go a long way on things that really need attention
I got a Performer intake for $75 & a 600 vacuum sec. Holley for $60 & I've got to get a thrott in the le plate kit with the ford kickdown for it, thats about $25. So theres $160 so far on the induction, a set of cheap flowtech headers are about $120, full gasket set $70, aluminum water pump $40, very mild cam & lifters, $110, elec. distributor $150, So what Im getting at is I don't want to have $1000+ in an engine, not for this project. I had $2500 invested in my Cleveland in a 70 Mach, but that was a show car, this is a shop truck & IM BROKE
I've put floorpans & patch panels in old mustangs before, but I have NEVER spread the first glob of body filler sooooo I'm gonna try my hand at some bodywork. Like I said, I'm not trying to make anything fancy, I want a reliable shop truck to haul mowers in, take to the flea market, haul scrap in, but just look cool doing it
