what headers 351w 2wd
pedro69ford
Post by pedro69ford »
I need help I realize they don't offer a windsor for the 69 f100 but I stroked a 408 and want to know if anyone has ever put headers on this setup I called hedman nothing hooker nothing has anyone ever tried a set that worked I would appreciate any help thanks guys I have a 351w with a c6 automatic 2wd f100 shorbed stepside thanks again
Dragon
Re: what headers 351w 2wd
Post by Dragon »
302 headers. Do a search on here 351 Headers.
Old Fords Rule
Was a Ford Service Tech
98 Volvo S70 2.4T Auto
My Gallery
Spark test
Caseys71
Post by Caseys71 »
:yt:, 289's, 302's, and 351w's are all Windsor short-blocks and most parts interchange between the 3. As dragon had said shop for 302 headers or 289/351 headers. Here's a page of them at summit:http://www.summitracing.com/search/Depa ... s=Rank|Asc
The reason they couldn't find them for you was because 351 Windsors weren't available in bumps.
Casey
16 years old with a 40 year old truck (well almost)
1971 F-100302, T-18 4 speed, 3:55 rear, & an Edelbrock sticker on the ashtray.
"Don't worry about what you become, just make sure that you're successful at what you do."- Mr. English
"Value what you DO have over that which you don't."- Forrestbump
"Wanting can sometimes be better than having, never stop dreaming... it's what keeps us all going."- Forrestbump
1984 Toyota 4x4: 22-R, 5-speed, 3" suspension lift, 35's and 5:29's
theskytoucher
Post by theskytoucher »
i have 302 headers on my 351w in my 68 f100 2wd! they work but just barely they are a royal pain in the a$$ to get installed! the other route i thought about taking is short tube headers that stay close to the block might work but i have never had a set to actually try them!
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
cdeal28078
Post by cdeal28078 »
When I had a 351W in my 71 I tried 3 different sets and never found a set that fit without hitting something. I either had problems at the starter area or the power steering gear box. I finally found an old un-used set of mid length headers with no names on them. Did some cutting and welding and got them to work pretty well
A buddy has a set of Thourly's on his race truck but he had to notch the frame on the right side
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
tybob81
Post by tybob81 »
BBK shorty 351w swap headers for a fox body fit realy good.
RTG_RACING
Post by RTG_RACING »
theskytoucher wrote:i have 302 headers on my 351w in my 68 f100 2wd! they work but just barely they are a royal pain in the a$$ to get installed! the other route i thought about taking is short tube headers that stay close to the block might work but i have never had a set to actually try them!
Are they long tube? If so what kind. I have had all kinds of sets and nothing woruld work without hitting something.
mrsnicks
Post by mrsnicks »
I remember reading a thread somewhere about this. Since 351W did not come in our truck you can't order an application specific header set. Someone mentioned you actually have to buy a set of 302's AND a set of 351's and use 1 side from each set to avoid running into hitting things.
Again this is all from memory of a post I read a long time ago.
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
eggman918
Post by eggman918 »
I have a set of '87 factory 5.0 shorty headers from a Lincoln mk7 them should fit.they are easy to find in bone yard.
you might find a pair and test fit them in a bump in the bone yard before you spend the money. :2cents:
flatblack
Post by flatblack »
http://cgi.ebay.ca/ws/eBayISAPI.dll?Vie ... K:MEWAX:IT these might be what you want, they are 351 specific, i know how much of a pita a 351 can be, in theory everything 302 will fit... with a hammer :D
Nitrous is like a hot girl with std's... you know you want to hit it but your afraid of the consequences
Farr1441
Post by Farr1441 »
I am looking for headers for my 351w in my 68 ford f100 and can't seem to find any, is yours an automatic or manual? Where did you find yours and did you put shortys on and then have pipe bent to fit?
IN2FORD
Post by IN2FORD »
I used a set of foxbody Ford Racing shorties. Clears the frame fine. Now I need to grab a mid pipe for a foxbody and see if I can make it fit with a few modifications.
Barry
HIO Silver
Post by HIO Silver »
BBK shorties p/n 1515
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
HIO Silver
Double post deleted.
Good write up on Sanderson thirties by our very own Pincheweddo (Thanks, Pinche!)
http://www.1967f100.com/2013/09/and-win ... n.html?m=1
