I got a 65,000 mile 1966 NP435 2wd trans that is absolutely MINT, with factory scribble and stenciling on it, to replace my who-knows-how-old-and-beaten NP435 in my 67 F100 4x4.
My questions is, again since it isn't detailed in the service manual, how does the output shaft of the trans mate to the tansfer case? My truck is at work and needs to be movable, so I will need to jump in, pull out the old trans and install the "new" one as quick as possible; does anyone have any tips or a how-to they are willing to offer up?
I got the gasket kits and I know the clutch is new and the transfer case is a new re-man.
Will I need to first remove the t-case from the trans and then pull the trans? Does the trans just pull straight back from the flywheel/clutch assy and then slide right back in?
Thanks again, your help has been invaluable!
