Rim Size
- skeeterg49
Rim Size
Hey Guys, I just searched the forum but couldn't find an answer to my question. I have a 1972 F-250 4x4 with a Dana 44 front and Dana 60 non-limited slip rear. The original spec. sheet from Ford said the truck came with 9.5 x 16.5-8TT tires. I don't have the original tires or rims but would like to know if 16" rims and tires would fit on my truck. I can't seem to locate too many 16.5" rims on the market. Sorry if this question has been asked and answered. Thanks for any information.
1972 F-250 4X4
460ci @ .040 over w/MSD
NP435 Trans. Dana 24 T-Case
Edlebrock carb and intake
35x15.50x16.5 Super Swampers
and
always has always will
- skeeterg49
re: Rim Size
I don't know if the 16.5's were split or not. The rims on the truck were on there when I bought it. Yes I do have the 8-lug pattern. I forgot to mention that the Dana 44 in the front is the Heavy Duty model. Thanks for the reply
1972 F-250 4X4
and
re: Rim Size
Hey, nice to be back, I've not been a participant for a while....yeah, I say go with the 16's....I have a 67 that had the original split rims and when they got worn this time, I decided to go with radials...the junkyard I went to had a 68 with 16.5's on it, but my original split rims were 16's, and I found a 72 dodge 4X4 with a real nice set of 16" white 8-lugs, so I just went with those, they fit fine....and just to make sure, I tried slapping on a ford hubcap from another vehicle on one of the dodge wheels before I bought them and it fit fine (the junk guy said they wouldnt).....ok, so now I'm "polluted"...hey, theyre just wheels, they'll come right off and if I ever wanted to be original for any reason, I kept the old split-rims
Recognition is the key to discovery
- 68F250
re: Rim Size
The old split rims were 16".
If you go the used wheel route, make sure they are off a Ford or Dodge, the Chevy steel wheels have a smaller center hole and won't fit. All aftermarket wheels incorporate the larger center hole so they fit all.
Barry
- 67F250CS
re: Rim Size
Our 8 luggers have 6.5 inch spacing on the lugs. That will give you many options. I dont think the newer Ford truck rims will work because they a 177mm spacing or somthing like that. Damn metric system!!
1967 F250 Camper Special
- 68F250
re: Rim Size
Yeah, if you go with Ford truck wheels you're good up to '98.
Barry
- skeeterg49
re: Rim Size
Thanks for all of the info. guys! That's why I love this site. I know I don't have many posts but I'm always on here reading and learning all I can from you guys. Who knows, maybe Dodge contracted Ford to make rims for their trucks just to have something of value on them.
Thanks again. Billy
1972 F-250 4X4
and
re: Rim Size
i had the same thing, i put my 16'' rims on in the summer months, and my old 16.5'' rims on in the winter.
re: Rim Size
My 70F250 4X4 did not have split rims. I am using Fords steel 16.5's but I needed to set up a spare and ended up buying American Racing Outlaw II's. Very nice!
70 F250 4X4, 460 Twin Turbo
There is no replacement for cubic inches!
