77 stang
77 stang
found one on craigslist for 400, will the front end suspension be what i'm looking for if i decide to go with the mustang 2 front end...for bags?
neverdonekustoms
lunchboxxx
1986 bagged n body'd toyota...ls 6.0 project
1967 f100 2wd swb bag project
1983 720 datsun/nissan all original shop truck/daily
99 mountaineer donor for the 67
lunchboxxx
Re: 77 stang
The Mustang front end that you get from Fatmans (or a similar vendor) is not actually a 100% stock Mustang II suspension...it's just based on that style. The stock Ford pieces won't be heavy enough to last long on a truck...and you'd still have a ton of fabricating to do, even if you were determined to make it fit.
Don't try to reinvent the wheel....just go with the kit.
My
My
- 69NVF100
Re: 77 stang
I have to agree although you may save a few dollars intially, it will probally cost you more in the long run to buy the used stuff then just buying a kit designed for our trucks.
1972 SWB 400 HP 347 cid, C-6, 2wd.
Re: 77 stang
Find a 03 and up crown vic @ the wrecker and unbolt it. Comes with aluminum cross member, disk brakes, power rack, sway bar and petty much bolts in.
I found one for $175.00 complete.
Re: 77 stang
wanna find me one??? ^^^^^^
edit holy crap you are in Calgary????
Seriuoly find me one... I will even pay you extra for your time!!!!
Re: 77 stang
yea thx for the advice guys, fatmans is a nice kit but doesnt fit into my budget build, the 03-up crown vicky front is what i'll probably do....dont mean to say i found better but...i sorta kinda did..
, from tire to tire $150 at lkq junkyard in tampa woot woot!.....problem is i didnt look at the year of the car, i took pics but i still cant determine the yr bcuz u really cant see the control arms...my bad i guess
would it be a good idea to buy the master cylinder and booster and all of that so i have a better braking system...or will it not work??
neverdonekustoms
lunchboxxx
lunchboxxx
- td
Re: 77 stang
neverdone,
just by looking at those pics that doesn't look like the removable alum. cross member the 03 and up has.
Re: 77 stang
what in the pics indicate that??.
neverdonekustoms
lunchboxxx
lunchboxxx
- td
Re: 77 stang
neverdone wrote:what in the pics indicate that??.
look at the last pic, thats steel not alum. the steel one are welded in not bolted like the alum. ones.
Re: 77 stang
i cant see any welds bcuz they come out blurry when i enlarge them....but u just saved me an hour ride if you can tell its not the right one for me..thx!
neverdonekustoms
lunchboxxx
lunchboxxx
