40 20 40 seat
Fake Name
Post by Fake Name »
Thanks- where did the seat come from?
1970 F250
2011 KTM 990 ADV
2003 KTM 525EXC
1971ford
Post by 1971ford »
there was a 40-20-40 in Convincor's truck that i got from him and it had two lugnuts under each bolt hole for mounting and a long bolt. and the gas tank was pushe din to allow for the center peice.
dont know how many seats are similiar mounting
ok that might not of helped
-Ryan
SecondCamperSpecial
Post by SecondCamperSpecial »
HayHauler wrote:all i had to do was put some 1" blocks in the corners where the bolt holes are. I did this about 5 years ago and havent had any issues with it. i took some crap from my friends over what i paid for the seat (500) but it was well worth it to me. took bout 30 min to install and trastically changed the interior, probably the smartest mod ive done. ill try to get some more pics up :thup:
Were you able to then just mount the center console on the inide bolt holes like the factory did? If so that is tomorrows project.
1968 F250 Camper Special 390
1964 Galaxie hardtop 352
1967 Cougar project
1993 F350 Crew cab 5.8
1988 Bronco 5.8 C6
1966 Mustang fast back project
New 1962 Falcon Gasser project
HayHauler
Post by HayHauler »
i found the seat in an Autotrader. and the center seat/console is mounted to the seat brackets, its one large frame so i just bolted down the corners where the blocks are.
No problem can withstand the assault of sustained thinking. -- Voltaire
fireguywtc
Re: 40 20 40 seat
Post by fireguywtc »
Has anyone fabed in 40/20/40 seats from a newer type superduty? More specificly the extended cab type bench seats with the seatbealts intergrated in them. That is what I want to put in my truck so I can have shoulder harness type seatbelts, just curious if anyone has tried this.
Bill
2024 F350 CCSB, darkened bronze
