proportioning valve location
I'd like to get some input on where people have located thier proportioning valve. Can you located it in different positions down near the steering box area? Thanks all
Mike
Mike
- floyd67
re: proportioning valve location
mine is on the crossmember right by the steering box
1967 f1oo "floyd"
2013 f-150 DD
2005 audi a4 (wife's car)
2013 f-150 DD
- Joshpow
I've seen them mounted on the crossmember that the beams mount to also. Right beside the steering box. Not sure where I'll mount mine when I do the disc swap.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
71 F-100 Custom SWB
02 F-250 Stroke
- td
here's mine mnagatani, its the stock Brkt. off a 76.
On '73-'77½ 2WD trucks, the disc-brake proportioning valve is located on a bracket on top of the steering box, directly under the master cylinder. On late-'77 thru '79 it's located on the back of the main front crossmember on the left side.
When building a whole new brake system, it's recommended that you locate the valve as close to the master cylinder as possible, for best results.
- mrtleavitt
I found a '73 with discs that had the proportioning valve in the same spot as my '69 f100 with drums. It fit perfectly! I have yet to found another one like it.
Ok thanks everyone for the response. Im going to hook up my brake system in the next week here and was wondering where I should mount the valve.
I found a 74 w/factory discs and as mentioned above, the factory proportioning valve was on the frame exactly where the distribution lock was stock on my 68. I bolted the prop valve in the same spot, but if I had known it was supposed to make things work better, I would suppose I would have located it below the master on a bracket as mentioned, would be easy to do.
When I changed my 66 to power disc I put the prop valve up on the fender well, just below master cylinder. I had to remake the front lines and use a union on the rear brake lines but it is very simple to do. It will make it very simple to change if that is ever necessary and I can inspect for leaks without crawling under the truck. I saw several in the local u pull it with factory brackets to mount it off the master cylinder bolts but didnt wont to have to flex lines out of way if I had to change master or booster
ED
ED
