Yes I'm working on my slick but it has a 302/t-18 going into it.
This is the z-bar bracket that was on it...
But noticed this will thread directly into the block. Did ford do it like this on some applications????
Is this right??
Is this right??
Jason
- iamthewreckingcrew
re: Is this right??
I think some of the smallblocks(newer maybe) didn't have the provisions to attach to the block. Seems like a lot of Mustang guys use a cable clutch instead.
68 F-100 Short Box 2wd
302/c4/3.50
81 F-100 Long Box 2wd
460/c6/3.00
92 F-150 Lariat 4wd
302/auto couldn't go wrong for $500
302/c4/3.50
460/c6/3.00
92 F-150 Lariat 4wd
- Thunderfoot
re: Is this right??
That is the spot that was / is on my 68 289/302 block in my mustang... I think it was the early blocks that didn't have it, like the early 289 and 260 pre 65 I think.
But that is the place on the block for it.
Shayne
re: Is this right??
All of the earlier small blocks I have worked on had the threaded bosses. 2 later 5.0 blocks had the boss for it but it wasn't drilled and tapped. 1 5.0 block didn't have the boss at all.
The 71 Mustang I had with a Cleveland used a bracket similar to that even though the Cleveland had a drilled and tapped boss.
Clint
Clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
- Wes
I have that bracket on my 67 fe set up. Looks like the second picture lines up nicely.
Wes
67 F250 High boy
69 Bronco
67 F250 High boy
69 Bronco
re: Is this right??
Thanks for the input!!!!
Both styles actually place the z-bar very close, other than the "stud" style positions the bushing closer to the frame. It will save me from stretching my z-bar.
Anyone have a good description or even a part number for the "fuzzy" bushing that is on the bracket above???
Thanks!!!
Thanks!!!
Jason
- 71PA_Highboy
re: Is this right??
Go to a classic Mustang shop.. Or online parts supplier.
I believe they are called 'Clutch Pivot Felts'.
HTH,
Eric
HTH,
Eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
