Fan Switch Removel.
worldsmysterie
Fan Switch Removel.
Post by worldsmysterie »
How do you undone fan switch.
69twotone
re: Fan Switch Removel.
Post by 69twotone »
That looks to be a 67 if it is...... There is a slot on the front that is inside the swith bezel. If you us a screwdriver with some tape or a cloth (so that you do not scratch the bezel) you can twist it so that the nut inside the bezel comes off.
69 f100 Custom cab Two tone maroon and white
Looking for a steering wheel with the horn ring, maroon or any color. PM me
worldsmysterie
so its just like taken the rest off just twist it like you would be unscrewing it?
69twotone
Post by 69twotone »
Depends on what you mean by the rest. The other two had nuts on the back. The fan swith has a nut inside the bezel right behind the knob on the front. You should see a slot in the middle of the swith on the front this is the nut I am refferring to. Let me see if I can find a pic
