I need to replace my master cylinder and was wondering if any of you have tips to make the job easier.
No power brakes, just hydraulic.
Master cylinder replacement tips
- 91Bear
- jor
re: Master cylinder replacement tips
Well, let's see... It's pretty straightforward. Just unbolt one and bolt in the other.
* Compare the new one to the old one before you get started to make certain you've got the right part.
* You do have to bleed the new master cylinder before installing it though. Just follow the directions that came with it.
* And you'll have to bleed your whole system as well and we can help you with that if you need it.
* You might consider painting your new one or it will end up looking like the old one in short order.
* Finally, use a flare wrench to loosen your brake line fittings. A regular wrench tends to slip. Good luck.
jor
jor
- 460 crew
Make sure when it's all installed and you check the levels its on flat or close to level ground or you'll have brake fluid on unwanted areas.
- flyboy2610
Wipe spilled brake fluid off of painted surfaces IMMEDIATELY!
