When my tranny is cold, it needs some revs to actually engage. This only lasts a couple of minutes, and then all seems well. Doesn't make any odd noises.
So...Start it, put it into reverse, needs some revs to drop in. If you let off the gas backing up, it drops out again. Put it in drive, same thing. End of driveway, same thing. Ditto the first stop sign. By the next stop everything is fine.
Adjustment? Fluid? I know nothing of this tranny, as I haven't had the truck long enough yet to get around to servicing it.
Auto tranny not dropping into gear
- flyboy2610
re: Auto tranny not dropping into gear
Which tranny do you have?
- 72hiboy4x4
check the tranny fluid when it gets warmed up. its low on fluid
my '74 did the same thing- 2 quarts later. it works great
- hardtailjohn
Try a new filter... sounds very suspicious to me!!!
John H.
John H.
Yeah, if the fluid is really low, the internal hydraulic circuits in the tranny won't have enough pressure to activate the shift clutches.
Jeremy
1971 Ford F250 CS, SC, 2X4, 390, C6
