Another Shoulder belt question
- 67merc
Does anyone have pic's of some one wearing a choulderbelt in our trucks? I'm not sure if the 68's on have the shoulderbelt hole drilled into the rear wall of the cab or if it was moved to the side.
I am wondering if the shoulder strap would ride too high to be practical. This probably wouldn't make a difference with my boys in seats with strap guide but they probably wouldn't want their mom losing her head!
Becca
- Big D's 69
My 69 has the hole in the back of the cab. I can't remember if this changed to the side in 70 or not.
re: Another Shoulder belt question
All bumpside trucks have the threaded hole for the shoulder mount. Look up behind you, it's probably got a black rubber plug stuck into it. Pop the plug out and viola', there you go.
Check out this thread for some pics:
http://fordification.com/forum/viewtopic.php?t=19728
- 67merc
Yeah, mine has the bolt holes on the rear wall of the cab. I was really wondering about it rubbing too high on my neck. Is there a part we could bolt on to guide the shoulder strap to a lower position?
Becca
Re: re: Another Shoulder belt question
Sure...it's the same thing used for children. It's called a 'booster seat'.67merc wrote:Yeah, mine has the bolt holes on the rear wall of the cab. I was really wondering about it rubbing too high on my neck. Is there a part we could bolt on to guide the shoulder strap to a lower position?
Since your truck doesn't have a shoulder-belt setup now, you're probably going to find one in a junkyard vehicle, so just find a setup from a van, for example. Since their attachment point is even higher than our trucks, they basically use an extension to allow it to drop down lower. Using something like that in our trucks would drop it down quite a bit. At work we have a '90-something Ford van with the setup like this, and I've been kinda eyeballing it for my own truck:
Or you could try something like this:
http://cgi.ebay.com/ebaymotors/Safe-Fit ... 2282QQrdZ1
- 67merc
FORDification wrote:Sure...it's the same thing used for children. It's called a 'booster seat'.67merc wrote:Yeah, mine has the bolt holes on the rear wall of the cab. I was really wondering about it rubbing too high on my neck. Is there a part we could bolt on to guide the shoulder strap to a lower position?![]()
Sorry, that was too easy.
I totally walked into that one!
That is exactly what would work!
I just happen to have a Ford van sitting in my driveway. Mr. Merc was joking about me parting it out... I think I scare the neighbours in suburbia as it is but I may not be able to resist tearing into the old van!
Becca
- 67merc
BTW, the carseat freak in me must mention that using the positioner shown in the link would cause major internal injuries in a crash.
Becca
