best door weatherstrip cement?
- averagef250
Anyone have suggestions for a real good weatherstrip cement for holding the stripping around the doors? Tried a few things including 3M weatherstrip cement and not too impressed.
- ezernut9mm
re: best door weatherstrip cement?
i used 3m general trim adhesive. i comes in an arisol can. i barely used any so i could remove the weatherstrip when i painted the truck in the future and it is working real good.
- jor
I used Permatex Super Weatherstrip Adhesive 80. It's also yellow. The stuff's kind of a pain to put on but it holds up well.
jor
jor
- theskytoucher
As i call it Yellow death because if you get it somewhere you dont want it, it will be the death of you trying to get it off!
Acually thats the stuff i put cork valve covers on with!
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
1976 Ford F-150 4x4
- FoMoCo
I like the thick rubber cement from the drug stores. Ross brand IIRC. The one with the little brush.
Nick
Nick
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
- Big D's 69
I always use the 3m brand in the tube that is black. I don't like the looks of yellow when it gets on the rubber if your not real careful.
- Sharkdance
Use 3M Weather Strip Adhesive.
Its a contact type of cement so you have to apply it and allow some time for it to 'tack up' but IMO its the best product to use for door seals.
Some folks dont like it cuz it can get messy is your not carefull.
You cant rush it. You gotta do just a few feet at a time before applying more.
Take a look at this thread:
http://www.fordification.com/forum/view ... 8367#98367
I hope it helps.
I hope it helps.
- averagef250
I've probably been impatient with the 3m stuff in the past. I've never had a mess, the weatherstripping just ends up falling off a few months later. I recently tore a cab down for painting and the stripping was held on with some sort of black adhesive. That stuff was really on there, but I could still peel the weatherstrip off without it ripping. Wish I new what the PO used.
- Big D's 69
I just pulled mine off and it was on with a black 3m adhesive. If I had been going to reuse it then it would have tore, but since I am replacing it with new then it came off just fine.
- averagef250
I know that. In the past I've had weatherstrip tore off from drunk passengers falling out and even had a girlfriend tear it off and try to use the weatherstrip as a shoulder belt. She was drunk too. Maybe my problem isn't the adhesive.
- Sharkdance
