Door Panel Restoration
- ezernut9mm
re: Door Panel Restoration
yep! looks awsome. glad your idea worked out.
THANKS john , the hard part was sewing the offset on the doors ! still need the cups for the inner door handles . And i still have some gremlins .
- slamons
this might be off the subject of fixing a door panel but, i seen a really cool idea for a door panel on a 69' the other day....the guy cut diamond plate same size as the original door panel and cut all the necesary holes and went around the edge with the crome plastic trim stuff you can buy to protect the edge of a door from dings when you open it....the just attached it with some stainless screws.....it looked pretty sweet actually.
