door seals... i need pics
- ezernut9mm
can anyone get some pics of their door weather stripping at the bottom? i would like to see what it looks like around the rocker plates or sill plates, you know-at the bottom. up and around the top and sides is pretty self explanitory, but i'm not sure how it should go around the bottom at the sill plates. thanks-chris
- rjewkes
i know it goes under them.
fuelly.com
fuelly.com
- ezernut9mm
- jor
re: door seals... i need pics
Here's are a couple of photos of the way I did mine. They flatten out under the sill and you poke the screws through.
jor
jor
- ezernut9mm
thanks for the pics jor.
- flyboy2610
Yep. Jor has it right. That's how they go.
- ezernut9mm
we have success! i didn't use alot of adhesive because i want to reuse them hopefully when i get the truck painted.
I replaced my weather stripping a few months ago, and now my door doesn't want to shut, unless I slam it. Is this normal? I was told that this is normal for a couples days, as the rubber is still hard. However, the door is still hard to close. Did I do something wrong?
Thanks,
Scott Kornhaus
Thanks,
Scott Kornhaus
1970 Ford F100 Sport Custom
2004 VW GLI 1.8T
2004 VW GLI 1.8T
- ezernut9mm
mine close harder than they did. not really a slam, but i have to shut it more firmly.
- Blue Cloud
You might have to slightly adjust the doors to get them to shut right. Just don't adjust too much or you'll have to adjust back when the the rubber forms up. As for reusing the seals, I would think for the cost it would better to just use new ones than fight a bad fit later on. IMO
- ezernut9mm
Re: re: door seals... i need pics
i hear what your saying. i'll have to see how they come off when the time comes, but for the price your probably right about getting new. plus lmc is about 20 mins away so i can just roll on down there and pick them up.Blue Cloud wrote:You might have to slightly adjust the doors to get them to shut right. Just don't adjust too much or you'll have to adjust back when the the rubber forms up. As for reusing the seals, I would think for the cost it would better to just use new ones than fight a bad fit later on. IMO
