Kick Down-Cable or Shaft
1970pickup
Post by 1970pickup »
I just put a 390 with a C-6 into my truck. I need to get the kick down hooked up. I cant find any info about if it uses a cable or a rod. Anyone know where to get info or the needed part. Thanks Jack
rjewkes
Post by rjewkes »
it should be a rod. Ive heard you can make one out of copper tubing if your careful and don't pinch it.
Also it similiar enough to the 73-up to 79 Automatic c6's and possably c4s so in a junk yard containing an automatic ford truck in the range from 1967-1979 Should have one unless its been plundered.
fuelly.com
Clarko
Post by Clarko »
Uses a rod if the engine has a carb. You can get a cable one that works just great from Lokar.
Brian
1969 F-250 Ranger Camper Special 465FE/C6 (waiting on AOD)
1988 Bronco 351W/AOD
1994 Bronco 351W/E4OD
