Amazon carb throttle to trapeze
yeye de qiche
Post by yeye de qiche »
Autolite 2150 off Amazon seen here. I’ve connected my throttle return spring to the round knob near the green line. I think the red line is pointing to the larger part where I hook to the trapeze. What do folks use for this bit? I fashioned a rod out of copper pipe, but I’m not happy with it. Is there a standard connection? What’s it called?
cep62
Re: Amazon carb throttle to trapeze
Post by cep62 »
It's hard to tell from that picture but you may have them reversed.
The small ball is used for a lot of throttle connections but a rod with a 90 degree bend can go in any of the other holes too.
and the spring can hook to any location in front or back as long as doesn't bind on anything.
yeye de qiche
So I’ve seen a connection to the ball knob (green) like the picture below. Is that hardware at the auto parts store or a big box like Home Depot? I don’t even know what it’s called.
So the spring I have forward (radiator fan side) of the carb should go the the lower spinner (red)?
Thanks for any help.
Generalee0527
Post by Generalee0527 »
The ball connector is called a ball stud and most napa stores used to have them. With few carbs on vehicles they may be scarce.
68 Ranger. 302 Clevor w/ 3 on tree, soon to have front disc brakes.
