Rust removal, engine block, truck is not running
Okay my 390 is currently stripped to do the timing chain I've removed the thermostat housing the temp sender everything on the front end, the radiator is out currently for clearance reasons (it was just easier that way LOL). There's a lot of goopy cakey looking bright orange rust that comes out of everything. The water pump is already been cleaned; the radiator was also taken off to flush it out, which is clean now. How do I go about flushing the block without it running and without making the most extreme mess in the universe??! I know the rust needs to come out or it's going to be an issue later on. I don't want to put it back together until it's gone. I'm not a mechanic, I will not claim to know what I'm doing! I just spent the last year and a half redoing my entire wiring harness and I'm almost finished with it! I'd like to be able to get it running once I put all the wiring back in. Please help, I miss driving my truck! It's been sitting for like 6 or 7 years now. I just want to put it back together and not have to tear it back apart again immediately. The engine is still in the truck. It is in a gravel driveway. I do have a kiddie pool to catch whatever in(it does not leak). But from there it's going to have to evaporate because I don't have anywhere on site to dump contaminated fluids. So any input as to how to do this with the least amount of liquid possible would be best! thank you, any suggestions would be great. I'm so glad that I found this website, I would have given up on my truck years ago if I hadn't have found you guys. I have learned so much I'm from you all you are amazing
Re: Rust removal, engine block, truck is not running
I have flushed them on an engine stand, they are messy and I see no way around that. I removed all frost plugs and blasted it with a pressure washer in every direction possible, then put a broken wire in my drill, stuck that in every place I could reach and pressure washed it again. Coat hangers, screwdrivers, anything you can scrape inside with, and take the drain plugs out, they are rusted in place and holding a lot of silt, but they have to come out. The engine will run a lot cooler once it has been cleaned out, and never run straight water for more than testing, the rust returns very quickly!
F. Noble, Saskatchewan.
If it's just rusty water , that can go in a gravel driveway in my opinion .
I had a crusty engine that I couldn't flush well , that would plug my heater core.
I rigged up a water filter for under sink use to my heater hoses and that caught a lot of small junk.
I would stay away from the caustic block cleaners, I've heard some bad stories.
Currently I still have antifreeze in the engine I am leaving it in there until I'm ready to do something about it. I've never had an overheating problem with this truck. That being said it has been sitting for a few years without it running but it has had antifreeze in it the entire time. I have never ran it with water in it. I have always had antifreeze in it. As I'm sure the two mechanics that owned it before me did also. The reason I removed the radiator was because I went to drain it and the drain plug wouldn't open and I was pretty sure it didn't come off but I couldn't figure out how to get it off either. As soon as I put vinegar inside of it and it hit that plug it cleared it! I have all new rubber, sensors, fittings, thermostat and housing and a freshly rebuilt water pump to put on it. Does anyone have an opinion on whether or not I would be able to put vinegar in it with it still sitting in the truck just for a few minutes and then shop vac it out? I do happen to have a 16 gallon shop vac and every little teeny tiny weird attachment that you could possibly imagine for it. That's my only idea at this point I can't remove it. I don't have a stand. I don't have a hoist and I don't have anywhere to put it or it would already be out. Thank you for any suggestions again.
There should be small pipe plugs , one each side of the block. I doubt if you can get out , those are the factory drains.
See if you can have access the the core plugs on the side of the block. If you think you'd be able to drive new ones in, you can knock the old one out .
That can flush a lot of crud out. It can be hard to put new ones in , in the truck.
Don't cheat and put the rubber ones in , I had one of those pop out.
The old wire coat hangers work good to loosen up the crud.
Thank you for the tip, I didn't know there was drain plugs in the side of the block! I will check it out and see if I can't find them and if I'm able to access them. You guys are freaking awesome!
I misunderstood just how far you were tearing it down, But ceps advice is good for a mid-life engine flush. The drain plugs may need heat to remove, also look for any signs or water leakage from the frost plugs, clean areas with rust. You could tap them with a hammer too, if one cracks or dents easily, it was rusted pretty thin.
I have also had a rubber frost plug pop out, if you have to replace one that is unreachable, just put a block heater in there, it will never pop out.
Well, I was never planning on tearing it down as far as I now have. Plus this is the second time I've had the timing cover off because I was sure something Was missing under it and I was right! My oil slinger was missing! So good instincts! But I also wanted to see how bad the rust situation was too. Original plan was just the timing chain. Wish I could do a full rebuild but I don't have a good space since it's outside.
