I feel stupid asking this. I can usually get anything apart, getting it back together without parts left over is the tricky part.
I can't seem to get the tailgate latches (#3 in the diagram below) off the tailgate (67-72). I removed the two bolts on each side that attach the tailgate latch to the tailgate but can't get the latches off. They're loose but still attached to the release bars or something. I can feel the spring tension when I pull on them. I'm guessing I have to get the mounting plate and handle off but those screws are stuck tight and soaking in Kroil. I'm pressed for time so thought I would try to get a jump on it if anyone could help with where to start. Thanks
Mark
http://www.lmctruck.com/icatalog/fb/0023.html
Help removing tailgate latches
- MAK
- Location: Georgia, Blairsville - Florida, Flagler Beach
- 68F250
re: Help removing tailgate latches
Yes, you have to remove the latch handle first. This will release the links that go from the lever to the latch brackets so you can pull the latch brackets out.
Sorry about that.
Sorry about that.
Barry
- MAK
Re: re: Help removing tailgate latches
Thanks! Hopefully the bolts will loosen-up by tomorrow when I try it again.68F250 wrote:Yes, you have to remove the latch handle first. This will release the links that go from the lever to the latch brackets so you can pull the latch brackets out.
Sorry about that.
- jor
If they don't loosen, you could try an impact screwdriver, the kind you smack with a hammer. They turn the bolt just enough to break it free. I used one recently with happy results on the phillips head bolt attaching the bed to a truck with the under-bed auxilliary tank.
jor
jor
- 68F250
Those hand-impact drivers can be a life saver! I have to use one on my old Honda motorcycles to break the phillips screws loose that hold the case covers on.
Barry
