427 FE head specs for C4AE H?
Does anyone know the specs to these heads? I am having a hard time finding them. Thanks
Re: 427 FE head specs for C4AE H?
Are you having trouble finding the specs or the heads?
1964 has got some yonder on it for sure but what I might try is to go to a "reputable" cylinder head overhaul shop. The one we use has specs on all the heads they overhaul, valve seat limitations, flow rates, and planing limitations which requires exact measurements for compression rates. If a head is not square or sit flat that would be the only reason I would plane a head, they do warp if the engine has been overheated. Happy hunting!
