240 carburetor year difference
the 67 came with an 1101 autolite manual choke. in 68 i think they changed to carter. is there anything wrong changing the 1101 to a carter yf? i dont know if they are jetted the same, ect. using the carter now. went to electronic ignition and the plugs are a light tan color so its not running rich. i can block the spark control valve and still run the 1101 if i need to. thanks
- JWW
Re: 240 carburetor year difference
You may want to try http://www.fordsix.com
They have forums and links specifically for the Ford six and there might be some good info for you.
JWW
1967 F100 Ranger, Auto, 240ci
2004 F150 Crew Cab
My project: http://www.fordification.com/forum/view ... &sk=t&sd=a
2004 F150 Crew Cab
