Hitches/Rollpan??
gonzalo medina
Hitches/Rollpan??
Post by gonzalo medina »
Hell I just welded in my new roll pan and it looks great but I also wanted to run a towing hitch but wonder whether one will fit now. The roll pan has changed the demention of the original bumper length. Could one be fabed or cut to fit how do these tow packages work?? There bolted to the frame right.
grounded72
re: Hitches/Rollpan??
Post by grounded72 »
if your rollpan has a license plate you can always be fancy and run the hitch behind the plate
PS: yes you can buy hitches that bolt to the frame
..................................... ___
..................._________|___\____
..;.;;.:;:;.,;.|__(O)____|____/_(O)|
flyboy2610
Post by flyboy2610 »
If you plan to tow any real amount of weight, then get a hitch that bolts to the frame.
