speedo gears C-6 please help
flyboy2610
re: speedo gears C-6 please help
Post by flyboy2610 »
If you still have the speedo gear from the tranny, put it in and hook up your speedo cable. Have a friend drive in front of you on the highway at a preset speed. Then see what your speedo tells you. If yours is fast, you need a gear with more teeth. If yours is slow you need a gear with fewer teeth.
You can also go for a drive on a highway with mile markers and compare the distance your speedo says you have driven in ten miles to the actual distance.
If you speedo says you have gone 12.2 miles, but you have only gone 10, then your speedo gear needs 1.22 times more teeth your current gear.
You can find speedo gears at:
http://www.nationalpartsdepot.com/
Look in the online catalog on page 150.
Hope this helps. :)
Comet
Post by Comet »
The right gear is a function of your R&P gears, the tire dia. as well as the tranny.
Check this out for some of the calculations (I know it's a chevelle link, but the info. applies :P ). There are several other web pages with similar info, so if this doesn't help, do a search for "speedo gear chart."
http://www.chevelles.com/shop/speedo.html
Or, just call Tacoma Speedometer with the axle and tire info and they'll set you up-(253) 582-3890
magnethead
Post by magnethead »
Speedo Error Percent = (difference between actual and indicated speeds / asctual speed) * 100
edgar.ford.67
Post by edgar.ford.67 »
I have a 67 ford truck with a c-6 tranmission...i changed my differiental to a 2.50, i did have a 3.50.. i need help setting my speedo gear
Friends dont Let friends drive chevys....
There's a lot of online info about how to figure out what speedometer gears you need when changing axle ratios. Here's a couple:
http://www.boss302.com/speedo.htm
http://www.tciauto.com/tech_info/speedo_gears.htm
