DIY Oil Pump Primer
DIY Oil Pump Primer
I would like to make an oil pump primer. I don't have a spare/junk distributor laying around to modify. I can see that a 5/16, 1/4" drive socket with an extension fits very nicely in the block.
My question: does the distributor body need to be in place to allow proper oil flow to the engine like a Chevy? I don't see the need but want to make sure.
Thanks again!
Larry
Thanks again!
Larry
Re: DIY Oil Pump Primer
The distributor doesn't have to be in place if it's a small block not sure about anything else. You can rent one from AutoZone if it's a small block.
That's the first place I looked. All that was listed was a Chevy and it's not even available. Same with Oreilly, NAPA and Advance. I'll see what happens with the socket...
Be careful and don't drop the socket down the engine
Yeah, the first time I tried it I thought I did! It was just the pump shaft sticking to the socket and falling back down in the pump.
- sargentrs
Just buy a piece of 5/16" stainless hex stock and use your drill. McMaster-Carr sells a 2' piece for about $13.
Cool, thanks. Thanks easier and safer.
You can spin it with a socket on an extension using a 1/4 drive adapter in dill, tape the socket to the extension.
- sparky72
This is what I do.DuckRyder wrote:You can spin it with a socket on an extension using a 1/4 drive adapter in dill, tape the socket to the extension.
Taylor
- basketcase0302
