460 engine perches
M-100
460 engine perches
Post by M-100 »
I'm going to install a 460 in a truck that is supposed to have had a 390 but currently has a Chevy 350. I have the factory 460 perches and mounts will the perches bolt in the same holes in the frame or will I have to drill new ones. Nothing against Chevy motors but they need to stay in chevys
M-100
Re: 460 engine perches
Post by M-100 »
:fr:
M-100
Post by M-100 »
:fr:
390FE1972
Post by 390FE1972 »
Here is a technical article that talks about engine perches, it does mention the 460 engine, not sure if this helps, but here it is:
http://www.fordification.com/tech/engine-perches.htm
Regards :thup:
cdeal28078
Post by cdeal28078 »
if I remember right mine pretty much bolted on.
71 F100 SportCustom
1986 Bronco 5.0 AOD
