"BIRD NOISE"
"BIRD NOISE"
HI GUYS:
I'd like you to help me on this:
My 67 has a noise that sounds like a little bird and goes faster the faster the truck goes, i think it has something to do with the transmissions since it gets louder when i shift on second gear, than when i shift on first and also that's where it seems to come from. When i let the pick up go down hill on neutral there's not such noise. (just fyi, the transmission is a T-18 ).
Any how i'm planning on taking her to the doctor, but i do like to know yr theories on this so we can go look for the right thing.
Thanks a lot i will appreciate your help
Regards
Regards
- binder56jd
re: "BIRD NOISE"
throw-out bearing?-jd
now serving #235
now serving #235
- heep70
Or U-joint.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- bluef250
re: "BIRD NOISE"
Check u-joints by grabbing driveshaft and turning. If you have play and slop and chunking then the u-joint needs replacing. Suggest you replace them all while you do the work.
- jzjames
re: "BIRD NOISE"
Im sure it's "tweetable"
- binder56jd
re: "BIRD NOISE"
-jzj- i didn't see that one coming
jd
jd
now serving #235
now serving #235
- bleedfordblue
re: "BIRD NOISE"
Definitely u joints. Try some grease.
I'd rather be shooting yankees....
and terrorists.
and terrorists.
- xxxtina63
re: "BIRD NOISE"
A carrier bearing on driveshaft will make noises like that. Mine was terrible.
My FORDification Photo Album
- FLATBEDFORD
Ivan, did you find your bird? It may have migrated to the Northeastern US, under my truck. Let us know if and how you fixxed.
My Photo Gallery
My Photo Gallery
- FLATBEDFORD
Truck came with the bird, free of charge.
My Photo Gallery
My Photo Gallery
- rjewkes
wheel bearings?
fuelly.com
fuelly.com
- FLATBEDFORD
re: "BIRD NOISE"
Mine only makes the noise when the truck is accelerating. Mostly 2nd and 3rd gear. Not so much in 4th. U-joints make sense to me because the noise is most prevalent when the drivetrain is getting the most torque.
My Photo Gallery
My Photo Gallery
yea thats probably what it is. put some grease to them and check the slack in them while your under there by turning the driveshaft back and forth. if it doesn't give you any slack then you have some miles left on them . if it clunks then they will have to be replaced before they drop your dirve line in the middle of the street.
