Holes in frame for rear bumper brackets.
4x4x4crewcab
Post by 4x4x4crewcab »
What does and how many holes are in your frames for bumper mounting?
I have a set of the non step type brackets and they dont line up for mounting.
First picture is of my frame and the second is a pic. sent to my from another members truck. Just curious as to what you all have back there.
Mark
1969 Volkswagen Karmann Ghia
1999 Ford Windstar
1983 Chevrolet Silverado p/u
1990 Lincoln Town Car
1998 Lincoln Town Car
4x4x4crewcab
re: Holes in frame for rear bumper brackets.
second image was sent to me from another member.
Mark
1999 Ford Windstar
1970F250
Post by 1970F250 »
mine has two but could use three because it moves. :eek:
binder56jd wrote: If you can't dazzle them with diamonds- baffle them with b------t
mine is like the second pic. and mine did move because the bolt came loose so i tightened it.
i think i have a aftermarket type of bumper.
capeclassics
Post by capeclassics »
My 70 SC is like the second pic.I think my step bumper is aftermarket because the space for the licsense plate is over on the left side instead of the centerof the bumper.I also have about 5 holes on each side of the frame about a foot and a half in front of the bumper bracket holes...no clue what those are for.
68F250
Post by 68F250 »
My 68 F250 2wd has different holes. The original step bumper uses these two lower ones.
Barry
heep70
Post by heep70 »
The boob that owned my truck before me welded it on :o . I have no holes :(
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
hey most guys like boobs
heep70
Post by heep70 »
Thats what i thought tell this one was born.
Greg
Fordfool
Post by Fordfool »
Hey! I recognize that second picture!!!! You should see that frame now!!
My Gallery
"Knowing is not enough, we must apply,willing is not enough, we must do" -Goethe
4x4x4crewcab
Thanks all for the responses. I'm still a bit puzzled as to all the frame differences, but yet the common standard set of brackets that everbody either wants or sells for the non-step type bumpers will or does fit these trucks for many diff. model years.
Fordfool I would like to see some update photos on your progress. Email me a couple if you get a chance
Mark
1999 Ford Windstar
67RED
Post by 67RED »
couple of pics i took
steve
Life is 90% how you take it10% what you make it
I always thought the factory mounted the sport bumper out too far....left too much of a gap between it and the box. When I get to the point of mounting mine, I'll have to redrill holes, but it's getting moved in as close as it'll get to the box without scraping.
OK, got you a few more comparison shots today while at the shop:
1967 F100 SWB 2WD
1967 F250 CS 2WD
1972 100 SWB 2WD
And you know what? I didn't notice this when I was taking the pictures, but once I started processing these pictures to post, I noticed that it appears that the rear section of frame is longer on the F250! :hmm: See how the mounting holes are farther away from the rear leaf spring bracket? I'm going to have to remember to actually compare the frame section measurements between the F250 and F100 the next time I'm at the shop.
68F250
Post by 68F250 »
Nice shots Keith!
I think what you're seeing is the difference between the short and long wheelbase frames. The long wheelbase frame has around 4" more from the rear axle to the end of the frame.
There's a 16" difference between the short and long wheelbases but a 20" difference between the beds, the extra 4" comes out the back.
Barry
