putting a 87 mustand motor 5.0 into a 72 f100 will it work?
I have a 1972 F 199 truck that the motor is worn out can i put a 87 5.0 mustang motor in it? truck has a T5 transmission in it.
- sargentrs
Re: putting a 87 mustand motor 5.0 into a 72 f100 will it work?
Yep. Just another small block 302. The T5 shifter probably won't be in a good position but you can adapt/modify it to work. You'll need a different driveshaft too and have to work out the clutch linkage. Our trannys use "push" mechanism to operate the clutch, T5s use a "pull" mechanism. A lot of threads on it. https://www.google.com/search?ie=UTF-8& ... cation.com
What Randy said
Oversimplifying, the engine should more or less drop right in, you'll just have to work out the shifter & linkage. Our 71 has a '98 Mustang 302 in it, and other than the fuel injection it looks essentially like any other 302. Of course we have an A4OD transmission, so we didn't have the issue of the T5 linkage
1971 F100 SWB w/'98 Mustang 302, A4OD, CV swap, 8.8 disc rear, PS PB and soon to be AC
2016 F350 King Ranch Powerstroke 6.7 Crew Cab 4wd daily
2008 F550 Powerstroke 6.4 Service Truck
2007 F250 Powerstroke 6.0 Supercab 4wd dually conversion
2000 E450 Powerstroke 7.3
2017 Explorer 3.5 XLT for the wife
2008 Nissan Rogue for the daughter
2001 S-10 rat rod for the stepson
2017 Yamaha 242 Limited E-series
