Water pump pulley rubbing and off
ebaby35
Post by ebaby35 »
Just replaced my water pump and went to put everything back together but now the inside of the pulley rubs the pump and is not in line with other pulleys. Can I shim it out until it lines up and doesnt rub. What are my options.
Busboy
Re: Water pump pulley rubbing and off
Post by Busboy »
It sounds like the new pump shaft was pressed on too far. I'd get another pump.
1967 F-100 4x4 custom cab.
ebaby35
Post by ebaby35 »
Thanks that makes sense
Busboy wrote:It sounds like the new pump shaft was pressed on too far. I'd get another pump.
