pulling the 'pumpkin'
67 short box
Post by 67 short box »
got me a donor 72 with 3;00 gears and trying to get the pumpkin out. got the axels pulled and the 10 nuts off.
I haven't got it to break loose yet. there's nothing left to hold it there. is it just the tight fit coming out or??
im thinking maybe a come a long for tension and tap with a hammer..thanks
cep62
Re: pulling the 'pumpkin'
Post by cep62 »
There may be copper washers around the studs that must be chiseled off.
then tap a good strong putty knife or two behind it and work it off.
sometimes they're stuck pretty good.
Busboy
Post by Busboy »
You can use your floor jack under the yoke to break the diff loose from the housing.
1967 F-100 4x4 custom cab.
67 short box
thanks to both of you
will try again tomorrow....
67 short box
it was those washers. got late yesterday, didn't see them. that's my excuse and sticking to it 8)
now to swap the 3:70 for this 3:00 or not with the 240 motor
sure wished it was a 3:50 instead of the 3:00 thanks....
jzjames
Post by jzjames »
67 short box wrote: now to swap the 3:70 for this 3:00 or not with the 240 motor.
Hope you don’t end up regretting this,...
67 short box
heard that. I think the 3:00 is going to be too much. the 3:70 sure seems low to me though
may wait to see if I can find a 3:50 gear. it gets terrible MPG
Red Mercury
Post by Red Mercury »
3.00 is too much gear for a 240. I have a stock 67 F100, 240, 3-speed manual. The truck had 3.70's, I switched to a 3.00 set, and now have a 3.25 set in it. The 3.25 is still too much gear for the stock coffee grinder 240 engine. Ford factory installed the 3.70's because it was the best match for that engine/transmission combination. I have heard others say that this works better with an automatic transmission but I don't have that personal experience.
My experience is that I have to ride the clutch a lot with the 3.00's and 3.25's to get the truck rolling. It is very hard on the clutch. At highway speeds, it lacks power for passing or climbing hills. I generally lose speed when I come to a hill. In a word "gutless". The only upside is that there was a small increase in gas mileage, maybe 2-3 mpg. Most assume that because the 240 is a small 6 cylinder engine, these trucks should get better gas mileage than they do. Not so. I am planning to put the 3.70's back in the truck.
jzjames
Post by jzjames »
67 short box wrote: it gets terrible MPG
I have the 300-6 , auto, in my shortbed with the 3.70 gearing. I think it’s the best gearing for this truck, wouldn’t change it.
I don’t think my mileage is that great either @ about 14/gal.
Ranchero50
Post by Ranchero50 »
3.00's will suffer, especially with a tall first gear and tall tires. It'll be OK with an auto and / or some lower profile tires. I'm a big fan of the 3.31's in my Jag and wish I'd installed them in my Mustang when I had it. 3.25's were a little too tall, 3.50's just smoked the tires too easily in third.
67 short box
ok guys, im not doing this change. yall have been there and done that. if anything, I may try 3:50 or im thinking 235x75 tires
I have 235x70 now. don't know if a couple of inches taller will matter. cant hurt. anyway, thanks for saving me a lot of work for nothing.
I appreciate the help.....
jzjames
Post by jzjames »
67 short box wrote:I may try 3:50 or im thinking 235x75 tires...
That should be perfect. I buy the 235 x75 tires for mine. Looks good on the truck.
67 short box
I almost bought the 235x75's but decided on the 70's..... :cry:
next time for sure......
jamesdfo
Post by jamesdfo »
**Less than an inch difference between P235/70 & P235/75.
There are any number of online calculators you can use to calculate your RPM @ a given MPH........
P235/70/15 235 70 15 27.95" Dia
P235/75/15 235 75 15 28.88" Dia
James
