Does anyone have a picture of correct, stock exhaust routing for a 360? Looking at the schematic, it looks like the drivers side exhaust loops under the oil pan or something. Can't tell what I'm looking at.
The one I just pulled out was pure, booger-welded craziness.
1970 360 exhaust routing pic?
- redstone65
Re: 1970 360 exhaust routing pic?
Yes it goes under the trans bellhousing.
1967 F-100 4x4 custom cab.
- redstone65
Thanks Busboy. The one I just cut out was routed behind the trans, under the tail housing. They didn't leave enough room to actually mate it to the manifolds though. So, out it came.
Pic:
Pic:
Yeah that's definitely a cobble job. I buy new header pipes from Napa or Summit.
- redstone65
Thanks for the advice. I think I found the parts:
Passenger side (main): https://www.napaonline.com/en/p/EXT40516
Driver side (crossover): https://www.napaonline.com/en/p/EXT42371
The new engine is from a 74 and has the ribbed exhaust manifolds. NAPA's site says the crossover pipe won't fit a 74. But, they look like the ports line up the same as the block style manifolds from the old engine (70 model). Is that right?
Those are definitely the part numbers that i have used on two projects, a 67 and a 72. I think the chassis is the issue not the engine as far as year model.
