240/6 power, or lack thereof
stink bear
Post by stink bear »
Anyone else have a 4x4 F100 with a 240/6, NP435,and Dana 21?
I inherited one and have been fixing it up. I like the old truck (72) but it doesn't have enough power to pull a whore out of bed and it only gets 11 mpg. It must have some pretty low gears because it turns about 2800 rpm at 55 mph. I would think it should either have decent power or get decent gas mileage but I get neither. I'm wondering if the engine / drive train combination is just weak, or if the engine isn't putting out the power it should. I did a compression check and that was good, it seems to run well enough, just lacking power. Anyway, I would like to hear from anyone else with a similar truck to see if their experience is similar.
I am planning to swap the 240 for a 302, but I'm still curious about the 240.
basketcase0302
Re: 240/6 power, or lack thereof
Post by basketcase0302 »
"stink bear"Anyone else have a 4x4 F100 with a 240/6, NP435,and Dana 21?
I would be willing to bet that it has 4.10 gears in the axles, (being 4 X 4) making it a pulling torque monster rather than a road warrior.
It would be real...easy to drop a SBF, (yeah...302 stroked out to a 347) or a 300 (which can be found for pretty cheap into it as a game changer. :wink:
8ton
Post by 8ton »
Have you done a full tune up on it yet? Tired ignition components and slow timing will make a fuel hungry dog out of most any motor. If you are serious about doing the swap sooner than later, it may not be worth the cost.
colnago
Post by colnago »
basketcase0302 wrote:I would be willing to bet that it has 4.10 gears in the axles, (being 4 X 4) making it a pulling torque monster rather than a road warrior.
On my 2WD, I have 4.10 in the rear, and I turn 2500RPM at 55MPH. In fact, my speedo is whacked out, and I've learned to gauge my speed by the tach, since it's rock-solid.
Also, I'm driving with a 352. I would love to get 11MPG.
Joseph
Jacksdad
Post by Jacksdad »
colnago wrote:Also, I'm driving with a 352. I would love to get 11MPG.
Joseph
I'll second that :thup:
Have you thought about a 351W? Later model roller cam motors are easy to find. Or if you're sticking with a 302, 96-01 5.0 Explorers came with either GT40 or GT40P heads depending on the year. With the exception of the mighty Boss 302, they're the best production small block heads that Ford made.
stink bear
First, I apologize for not replying sooner, I didn't get email notification that there were more posts. I thought the thread died.
Thanks for the replies.
I don't recall if I've done a full tune-up but tonight I checked the timing, it was varying about 6 degrees, I think the dizzy is worn out.
I have considered a 351W. I already have a 302 out of a 77(?) truck I would like to transplant. I'm not looking for much performance, mostly driveability. With the truck having such low gearing I think a stock 302 will have plenty of power and the shorter stroke is more suited to the higher rpm's.
The torque of a 351W might be nice at times, but the truck is mostly driven on the street, the 240 pulls it around okay on level ground.
I am about to make a post about parts needed to install the 302, it came out of a truck with an automatic tranny. my truck is a manual. The post will be in the drivetrain forum.
jzjames
Post by jzjames »
Don’t think throwing in a stock 302 is going to give you the results you’re lookin for, just my opinion.
stink bear
jz - I considered that I won't get the power I want out of a 302. I think it's worth a try, and if I don't get the power I want an upgrade to a 351W would be easy.
I also considered dropping a 300 in it, that would be real easy. I had a 79 F150 4x4 with a 300 many years ago. I believe it had 3.55 gears, it had plenty of low end torque but in my opinion lacked top end power.
I appreciate your 2 cents.
jzjames
Post by jzjames »
Yes, opinions are like,...well, you know. Everyone’s got one. :wink:
I’ve had a shortbed F100 with a 302 and my current shortbed has the 300 I6. I think both had 3.70 differential.
For comparison they were both pretty much the same power-wise, maybe the 300 had an edge- (lighter).
You have a sought after 4x4 shortbed but for cruising, the 4.11 gears are not going to do it for you.
Maybe the 351W is the ticket with a different rear gears. I don’t know anything about the 351W. If it was me I’d put in a well built 300 Six, figure out the rear diff. That would be better on gas and probably fun to drive.
It’s going to be hard getting it to cruise like a modern vehicle. :2cents:
colnago
Post by colnago »
stink bear wrote:I had a 79 F150 4x4 with a 300 many years ago. I believe it had 3.55 gears, it had plenty of low end torque but in my opinion lacked top end power.
I recently had multiple threads going about increasing the performance of my 352. The single common answer that came back was having to determine what I wanted from the engine. I decided that low-end grunt is more important to me than having a road rocket. With my C6 tranny and 4.10 rear end, I turn 3,000RPM at 65 MPH. So, the RPM range I care about is 0 - 4,000; over that, I don't care, because I will never see it.
I guess this is my long-winded way of suggesting that you decide what you want out of your truck, then decide on the engine/gearing/tires that can give that to you.
Joseph
